Results 1 to 6 of 6
    7,441
    BoingBag problem
    I just installed OS3.9 to use with WinUAE as I'm using it for different paint/image tools/programs. When I try to install BoingBag, it says that I need to install OS3.9 first, that BoingBag isn't intended for OS3.5??
    Wtf, I have installed OS3.9
    16,058
    How did you install 3.9?
    7,441
    From CD. I made a cd0 drive in WinUAE, then installed it to my HD. The installation worked perfectly.
    Only thing bugging me, but only a little bit, is following screen which disappears when clicking Ok.
    And that's why I thought to also install the BoingBag's.
    16,058
    I've never installed 3.9 directly, instead going for a 3.1 to 3.5 to 3.9 upgrade route. Much more long winded but it has always worked. Maybe the missing libraries are from an earlier version such as 3.1?
    Deadly VIP
    TiredOfLife's Avatar
    May 2006
    1,031
    I have installed 3.9 to a blank drive.
    The Workbench library should be there.
    Makes me wonder what else is missing.
    Might explain why the boing bag thinks it isn't 3.9
    I would try installing again.
    I take it you know there are two bags for 3.9?
    7,441
    Yep, and there's even an unofficial 3. I already installed them while I was using AmiKit, but I removed it from my disk some time ago.
  1. A600 hard disk problem.
    By wilsonsamm in forum Hardware
    Last Post: 21st May 2007, 08:47
