Results 1 to 5 of 5
    Harmless retrojunkie's Avatar
    May 2013
    scotland
    A500+ power no video output
    Hi Guys, I just dusted my old 500+ out of the loft and have a problem. No video output. I have power and disk light on constantly, caps lock light goes on and off when I press it. I have tried an old-school monitor as well as an lCD telly with no luck. could you point me in the right direction please. sorry for lack of info but im a noob in the Amiga scene.
    thanks in advanced.
    2,169
    Just wondering, did you try both the RGB output and the mono output, or just one?
    Mostly Harmless Aughie's Avatar
    Jun 2015
    27
    500 pluses have an oldsyle backup battery inside and if unattended for a long time this leaks acid with some very nasty consequences for the miggy.
    This guy is videoed fixing this. The 500plus in question woud only output a green screen nothing else.
    16,082
    It is surprising what some people in the community can do with damaged motherboards. The A4000 has a similar battery and leaking is a very common issue with them, causing widespread corrosion, track damage and even damaging the SIMM sockets. All can be repaired by someone in the know. Quite amazing what they can do. Way beyond my simple soldering skills.
    1,364
    Eeeeek! - Utter carnage......
    But as H says, probably quite repairable in the right hands.
  1. A600HD screen output blue hue
    By papapumpnz in forum Hardware
    Last Post: 13th October 2010, 23:15
  2. Unstable 60hz output from my A1200(T)
    By woody.cool in forum Hardware
    Last Post: 16th April 2010, 17:27
  3. Replies: 3
    Last Post: 18th February 2010, 14:46
  4. No video on power up on A600
    By jbenam in forum Hardware
    Last Post: 30th August 2008, 10:35
  5. WinUAE 1.4.0 AVI output mutes play session
    By Agram in forum New Users Area
    Last Post: 12th March 2007, 11:34
