Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    7,446
    Beta 25 (RC1) (Final in end of November. Really.):
    - Switching to interlaced mode and autoscale enabled: don´t calculate new size until 2 frames have been drawn to prevent multiple display size changes.
    - More accurate GUI resizing algorithm.
    - Show also first few bytes of disk in harddrive selection GUI.
    - Add real harddrive as IDE: calculate physical CHS values using H=16,S=63,C=total blocks/(H*S) formula to better match with real hardware. (ROM built-in IDE drivers use IDE identify device CHS values to calculate last accessible block of drive, LBA support was added in ROM updates)
    - Action Replay 2 copper list detection code hang tweak.
    - Prowizard AC1D update (Asle)
    Toni Wilen is online now Reply With Quote
  2. #22
    7,446
    Beta 26 RC2: (1-2 weeks to go)
    - RTG aspect ratio setting was loaded to wrong variable from config file (filter panel aspect ratio, not RTG)
    - CD32 CD audio play delay timing fixed. (Was originally timed using bad Liberation CD image)
    - RTG on screen leds was rendered twice in D3D mode (D3D sprite and software method).
    - Audio 14bit to 16bit scaling introduced extra low level noise.
    - Only enable AUDxPER limit hack (to reduce CPU usage with weird programs) if audio DMA is active. Manual AUDxDAT audio software may use higher periods.
    - Fixed rare crash in input/gameports panel test/remap support.
    - Added on screen leds per-led enable/disable config file support, for example show_leds_enabled/show_leds_enabled_rtg=power,df0,df1. In future versions order of led names are also supported and gaps in place of disabled leds will be gone.
    - DPI GUI size compensation disappeared (b25).
  3. #23
    7,446
    Beta 27 RC3:
    - Modulated volume value wasn´t range checked, caused noise if volume word was not between 0 to 63. (Platou title music)
    - Fixed SPTI mode CDFS crash.
    - CDFS didn´t correctly remove hidden trailing ;1´s in some Joliet CD filenames.
    - SPTI standard CD access: Use READ (10), not READ CD when requesting standard 2048 byte user sectors, not all BD/DVD drives support READ CD when reading DVDs.
  4. #24
    7,446
    Beta 28 RC4: (Final on 2-3 days unless something really bad happens)
    - uaescsi.device SCSI sense data is now returned correctly (For example MakeCD shows error messages that make sense now)
    - AHI channel swap also swaps AHI recording channels.
    - BMP screenshots were corrupted.
  1. WinUAE 2.4.1 Betas
    By Demon Cleaner in forum WinUAE
    Last Post: 7th May 2012, 17:41
  2. Missing Betas
    Last Post: 27th October 2008, 22:57
