Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Average Andrew1971's Avatar
    Dec 2010
    Northallerton
    194
    Tiago how are getting on with is project have you got any further with it ??
    As i am tempted to have a go at something like this
    Many Thanks
    Andrew1971
    A600 6gig HDD, 3.1 Rom, ClassicWB GAAE, Pcmcia Adapter to cf.
    A1200 80gig HDD, 3.0 Rom ClassicWB Lite.
  2. #22
    well, i stoped a bit, because my iron solder broke up, i need a new one. I almost have every components that i need, except the iron solder.
    I will try to give it a boost this weekend.
  3. #23
    Dec 2010
    Northallerton
    194
    Tiago dont forget to take some photos with some close ups. And how its going to laid out in the case approx.
    Hope i am not asking for much Thats when you have the time.
    Many Thanks
    Andrew1971
  4. #24
    Yes yes, i am taking photos of it.
    Are you thinking in doing something similar? with a laptop mboard?
    You do need to mesure the size of it, my mboard is going to fit inside upside down with a strange angle... the only way possible.
    Do you have a keyrah?
  5. #25
    Dec 2010
    Northallerton
    194
    No keyrah at the moment just took out laptop mboard last night it came from a time laptop called collosus big thing small ish mboard.
    I'll see if my camera is any good on me phone for pictures.
    Many Thanks
    Andrew1971
    Update
    motherboard is 10.5 inch by 8.5 inch
    plus a small board that plugs in to give 4 usb a ps/2 mouse and power socket that should able to go any where on an extenstion leads
    That's whats going in hopefully
    Attached Images Attached Images
  6. #26
    That looks very small...
    ha, i would like one as small as that one... mine is huge...
    what about the power on button? Is it a button? switch? Or you do the power on button by the leybboard like mine?
    what amiga case are you thinking?
  7. #27
    Dec 2010
    Northallerton
    194
    Tiago the power button is on the mboard (iam sure thats what it is) not on keyboard
    Well considering my A1200 case as iam using the A600. In the next few days i will be testing the board to make sure it still works. Your mboard does look big.
    Many Thanks
    Andrew1971
  8. #28
    if it is on mboard, then just solder 2 wires to a simple on/off switch. And bring the switch to outside the case. the composite hole could be a good. I found onw switch that has exactly the same size as that hole.
  9. #29
    Dec 2010
    Northallerton
    194
    I will be using alot of the stuff i already have. I will have to buy some stuff though trying to make it a buget build. So now on hunt for bits i've got see what turns up.
    But still going to test first. i'll be testing using a usb stick with pupy linux, no HDD or Cdrom it better work
    Many Thanks
    Andrew1971
  10. #30
    Oh, all the talk really is enticing me to do the same. However, rather than a laptop motherboard I've been wanting to utilise a mini-itx board with a dual core atom or maybe the faster ones now available with Core 2 sockets. Would be great.
    Also this project is one I could actually see a Catweasel being useful, as a PC floppy could be founded in the A1200's floppy bay and connected up, so real Amiga, other system, and PC disks could be read.
    Are you both going to wire up the A1200's LEDs for Power and HDD access? Would really finish it off.
  1. WHDload Registration Key location on Amiga A1200
    By poundrick in forum WHDLoad
    Last Post: 24th August 2012, 15:35
  2. Roger Waters - The wall tour 2011 started here
    By Tiago in forum General Chat
    Last Post: 22nd March 2011, 15:09
  3. PC keyb in Amiga, only in A1200?
    Last Post: 17th August 2008, 09:04
