Results 1 to 3 of 3
    7,456
    E-UAE 0.8.29-WIP4 for PS3 release 7
    New UAE version for the PS3:
    - compiled by using psl1ght sdk
    - The full uae documentation is stored in the ´docs´ subdirectory, here
    you are reading the ps3 port info.
    Features:
    - 68000, 68010, 68020, 68040, 68060 processor cores
    - OCS, ECS and AGA chipset
    - amiga hi-res (720x576) graphics resolution in 32bit depth
    - joystick1, joystick2 (2nd joypad required) and mouse emulation
    - options dialog (supports switching of the disk files and more)
    - sound in 48000 kHz
    - keyboard emulation
    - support for loading zip and dms floppy images
    - support hor harddisk files
    - save-state saving and loading
    - reads either /dev_usb000/uae/uae.cfg or /dev_hdd0/game/EUAE00829/USRDIR/UAE.CFG
    configuration during startup!
    Requires:
    - ps3 ready to boot homebrew programs
    - kickstart rom - see docs/readme
    Controls:
    - CROSS - joystick button 1
    - SQUARE - mouse button 1
    - TRIANGLE - mouse button 2
    - CIRCLE - user defined keyboard key
    - press R2 to activate virtual keyboard (vkb), release R2 to hide it.
    If vkb is shown press left/right digital pad to select the current
    key. Press the ´up´ digital pad button to actually simualte key press
    of the current key. L1, L2, R1 ann CIRCLE buttons are user defined keys.
    If vkb is shown press L1 to define L1 button, press L2 to define L2 button
    and press R1 to define R1 button. Later on (when keyboard is hidden)
    if you press L1, L2 etc. it will simulate assigned key press / release.
    - joypad 1 (emulates joystick 1 and mouse 1)
    - joypad 2 (emulates joystick 2) - if you want to enable 2-joystick mode, plug-in
    the second joy pad, restart uae and switch the port mode to "joy-1 & joy-2" in the
    options dialog.
    - left analog pad emulates either mouse movement (by default) or joystick.
    Press R3 (right hat) to switch between mouse and joystick control on left hat.
    Speed-up of the mouse cursor movement can be changed in the options dialog.
    - press Start to enter application menu, you can load ADF files from there.
    - press CIRCLE to exit the application menu
    Additional info:
    - The program reads uae.cfg during startup. In this configuration file
    you should specify all required parameters (memory size, kick rom, initial
    floppy disk files, cpu core, chipset etc.).
    - Files (kickrom, adf files) are accesible from either usb disk or internal disk.
    - NTSC support: press and hold CIRCLE button during emulator startup to initialize
    480 lines /60 Hz video mode. If it doesn´t work for you, you can press and hold
    TRIANGLE button during starup to use the current video mode set in dashboard.
    Make sure to change emulator options to actually emulate ntsc amiga machine by
    setting ntsc=true in your configuration file or in options.
    - Save states are stored in your harddisk directory
    /dev_hdd0/game/EUAE00829/USRDIR/SAVE
    - to use harddisk file: enter options and mount it the "Hard files" submenu.
    Alternatively you can specify the harddisk in your configuration file
    by adding the following line:
    hardfile=read-write,32,1,2,512,/dev_usb000/uae/system.hdf
    or, if the previous one doesn´t work for you:
    hardfile=read-write,0,0,0,512,/dev_usb000/uae/system.hdf
    Normally you just need to change the path and filename of the hardfile. The
    first four numbers are the default ones and should work even if your emulated
    disk file has a different size. The first set of numbers is ok for hardfiles
    formated to OFS (old file system), the second set (zeros) is for harddisk files
    formated to RDB (fast file system).
    Credits and thanks:
    - UAE team and porters.
    - RCDRUMMOND for E-UAE
    - psl1ght sdk team
    - PS3 homebrew scene
    Release log:
    r7
    - harddisk file can be mounted/unmounted in options menu
    - fix for multiple simultaneous keyboard key presses
    r6
    - bugfix release (fixed processor core switch, couple of other glitches)
    - added 800% floppy speed option
    - added QUIT E-UAE option
    r5
    - updated to the latest E-UAE 0.8.29-WIP4 source code.
    - support for harddisk files
    - suport for save-states and save state thumbnails
    - modified options dialog (more options are now configurable)
    - support for drive sound (new feature that was not finished in WIP4 code)
    - RETURN key added to the virtual keyboard
    - left analog stick can be used to emulate joystick (R3 switches between mouse and joystick
    mode of the left analog stick)
    - fixed 2 controller mode: now 2 mice can be emulated as well.
    - options dialog hooked up as an euae´s gui interface
    r4
    - unpublished release, vsync modifications
    r3
    - options dialog has more space for filenames
    r2
    - added support for uae.cfg stored on hdd
    r1
    - initial release
    Nice to see they are still working on this. Shame it is still only keyboard emulation and not USB keyboard support yet though. Definitely limits it.
    Just in case anyone trys to do it:
    you must copy the settings you gave in your winuae for the HDF file. But be aware,
    32,1,2,512 dont match the same order then in winuae... in winUAE you have A,B,C,D and in PS3/UAE it's like A,C,B,D or something like that.
  1. MorphOS 2.4 - First Release for Mac Mini
    By Puni/Void in forum PPC
    Last Post: 16th October 2009, 16:11
  2. PSP Scene release project
    By Harrison in forum Handheld Gaming
    Last Post: 4th January 2008, 12:12
  3. X-Amiga beta release is available now!
    By Bloodwych in forum Software
    Last Post: 21st November 2007, 14:37
  4. Replies: 1
    Last Post: 26th September 2007, 19:23
