Results 1 to 4 of 4
    USB power question - please
    Hi,
    i would like to know how can i turn on and off a USB port.
    My objective is to turn on a lamp/bulb.
    The USB has 4 wires, i guess 2 for data ; 1 for + and 1 for -
    so i can plug a small motor to make a switch click in a lamp/bulb by coneecting the + and - (pins 1 and 4 i think)
    My problem is how to turn on/off the usb motor.
    Windows have an option to usb power safe, so i guess it could turn off the usb and on again.... but all usb at the same time(?)
    I know i could just unplug the usb, but i want to do it outside my home, like being at work connecting to my home PC (there is software for that) and turn on webcam and also a light in room.
    anyone have an idea on how to do it? without any complicated circuits...
    thanks
    I think it would have to be a software controlled circuit board connected via USB. I don't think individual USB ports are controllable individually because the USB port needs to connect to a USB device so that the OS has a device driver to communicate with the device and its own interface.
    Have a look at http://www.pc-control.co.uk/motorbee_info.htm for some ideas. They have loads of USB control modules and not too expensive.
    Are you after a USB controlled relay?
    Alternatively, a powered external hub with something else controlling the power (but then that's another layer of fiddling about).
    That looks very interesting !!!
    I will read more about it
    thanks !!
  1. I'll buy my PS3 next this weekend... question
    By Tiago in forum Modern era (7th Gen onwards)
    Last Post: 15th August 2010, 17:45
  2. Technology Tv change CRT out LCD in, question
    By Tiago in forum General Chat
    Last Post: 18th December 2009, 15:54
  3. FPU - Question - Yes or No?
    Last Post: 28th December 2008, 16:23
  4. ebay - question
    By Tiago in forum Buying and Selling
    Last Post: 12th November 2007, 16:41
