Results 1 to 8 of 8
    Viotto's Avatar
    Sep 2010
    Question OnEscapee - problem when trying to save game
    Hello, this is my first post on this forum
    Has anybody played OnEscapee? Seems a very good game to me...also because I am a big Another World and Flashback fan
    I tried to play the free version released for Windows, but whenever I try to access the saving / loading menu, the game crashes.
    So I downloaded WinUAE, Kickstart 3.1, Workbench 3.1, and the Amiga version of the game. I set everything up, and now I am able to play the Amiga version without crashing when accessing the save / load screen.
    But there is another problem: the save option and the load option are disabled!
    Why are them disabled?
    I would be very grateful if anybody can help me.
    Thanks
    Another World fan since I was 4 years old :p
    Can you give any more information on how you have the game setup?
    From memory the game comes on CD, or ISO if downloaded, and needs to be installed to Amiga HDD to play. If you have a hardfile/HDD setup in WinUAE with Workbench installed and onEscapee installed then the game should load and save games to the HDD.
    You can try adding a line to the Workbench user-startup file to see if that helps.
    From Workbench, open a new shell/cli and type
    Code:
    ed s:user-startup
    Once loaded, add the following line to the file and then save it.
    Code:
    Assign >NIL: onEscapee: DH0:Games/OnEscapee
    Replace the DH0:Games/ part with the location where you have the game installed.
    Then reboot the Amiga and play the game.
    Hope that helps.
    Forgot to mention. If that doesn't help, then we have a version of OnEscapee available for download from our main site here. Unless you are using that version already. We also have all of the manuals for download which might help you further.
    Viotto's Avatar
    Sep 2010
    Thank you for your reply, I downloaded the game from here already by the way
    So my setup is:
    - I load Workbench 3.1 in floppy drive DF0
    - Onescapee.hdf loaded as hardfile in device name HD0 (read/write is checked)
    The "onescapee" file I must open to run the game is in HD0 drive (named OnEscapee):
    I enter this line in the file and save, but nothing happens when rebooting Workbench:
    And the saving option in the game is still disabled. Any help?
    Thank you
    I will gave the game a try on Monday for you and see what I can get it to do.
    Viotto's Avatar
    Sep 2010
    Thanks
    By the way could it be that it has got no space on disk to save on? I don't think so by the way since you can see from the screenshot that the game drive has got free space on it... I also left checked "read/write" checkbox so it should have write permissions on its own disk
    As you booted from an ADF of of floppy disk or Workbench, it might be trying to save to the floppy disk, not the HDF harddrive, and the save file might be too large for that.
    I've not had chance to try it out myself yet, but you might need to create a booting HDF hardfile with workbench and the game on it together for it to save. I will let you know.
    Viotto's Avatar
    Sep 2010
    Hello,
    have you tried it out already? I am still looking for a solution to it!
  1. Help with Winuae Elite save crash
    By spenoultrasonics in forum Amiga Emulators
    Last Post: 3rd May 2010, 16:24
  2. Save Ed
    By Buleste in forum Codes, Cheats and Walkthroughs
    Last Post: 20th October 2008, 14:45
  3. game problem in classicwb winuae
    By Tiago in forum ClassicWB
    Last Post: 18th October 2008, 14:45
  4. Replies: 6
    Last Post: 6th December 2007, 21:34
  5. It came from..........save problems!!
    By Krenzathal in forum Games
    Last Post: 26th November 2007, 22:06
