Results 1 to 10 of 23
Hybrid View
    Tv change CRT out LCD in, question
    Hi everyone,
    i am going to change my TV-CRT to a new LCD.
    Some advice please:
    must be/have:
    - Full HD
    - 32"
    - input 2 x Scart 21 pin (euroconecter)
    - input 2 x hdmi
    - VGA input
    don't care about sound i use external amplifier/speakers
    what can i buy around (500/600) euros
    so far i found this one nice:
    http://www.consumer.philips.com/c/te...5D.app101-drp3
    Do you have a big difference between 50Mhz and 100Mhz? in CRT you can see it, and in TFT?
    Can anyone point me others TFTs in 500/600 euros range?
    Thanks
    I highly recommend Samsung HDTVs. We have one as our main TV and it has a great picture. We recently upgraded to SkyHD and the picture quality is really good. And while you said you are not bothered about audio, this TV also has great sound. The menu system is also very nice with loads of advanced features.
    Standard definition also looks very nice on Samsung TVs. On other makes I've always been disappointed with normal resolution images as they appear quite pixelated and poor quality.
    For the money you have to spend you could actually afford a larger 40" Samsung LCD. The series 6 higher up series ranges by Samsung are worth looking at.
    The other make worth getting is Panasonic, but they cost more and I think the picture quality of Samsung is equal, and sometimes better.
    Philips image quality is also pretty good. We have a small Philips LCD in the bedroom which does have good picture and sound, but I don't think they are as good as Samsung or Panasonic.
    About about connecting the Miggy? Do they need anything special, or any TFT will display the miggy?
    Most have VGA or DVI inputs for higher resolution modes, and also have the more standard RGB SCART, S-Video and RT aerial sockets. So you can connect an Amiga easily.
    I connect mine using an RGB scart cable.
    Yes, in my CRT i use scart cable too.
    What about WB in vga modes?
    Most have a DVI port, which you can plug a VGA cable into with an adaptor. I've not tried an Amiga on the TV in VGA mode but it should work. I connect the PC up quite often.
  1. MAME CHD files 130u1 undergone change
    By Demon Cleaner in forum MAME
    Last Post: 25th March 2009, 22:19
  2. FPU - Question - Yes or No?
    Last Post: 28th December 2008, 16:23
  3. Career change - ever thought about it?
    By Sharingan in forum General Chat
    Last Post: 2nd March 2008, 20:58
  4. ebay - question
    By Tiago in forum Buying and Selling
    Last Post: 12th November 2007, 16:41
