Results 1 to 4 of 4
    16,658
    Bargain replacement fog lights!
    I just managed to get a bargain on evilbay. A pair of front replacement fog lights for my Peugeot 406 for £20!
    The reason I needed replacements for both is a bit of a mystery. I've owned the car since it was 2 years old. It is now 11 years old and still going strong. And in all that time the front fog lights have been perfect. However within the last couple of months I suddenly noticed one of them was cracked right across the middle. It still works fine but the whole of the glass is cracked right through so water will probably get in eventually, and the glass could fall out if a heavy jolt happens whilst driving. Then about a month ago I was cleaning the car and noticed the other fog light is now cracked in much the same way. It's also still complete and working but with a crack running right across the glass and some additional cracks running down into the corners. This one looks like a big stone thrown up from a lorry could have done it as I can see what looks like an impact chip. But what was the likelihood of driving the car for 9 years and suddenly both front fog lights breaking within months of each other? Very odd.
    Now I just need to work out how to actually remove the broken ones and replace them. I've got the Haynes manual but they are never that easy to follow. Although I've never bothered following a manual before when replacing rear lights or headlights in cars before now, so how hard can it be?
    7,667
    There's only some bulbs/lights you shouldn't touch with your bare fingers.
    16,658
    Very true. Xenon headlight bulbs especially. They reckon it can reduce the life of the bulb to just a few months if you touch them.
    I'm sure removing the actual light units will be quite straight forward. It is just working out how to remove the protective floor that sits under the front bumper/skirting on the car to get to the actual units that might be a bit head scratching.
    Poor Inactive Member
    1980-20..'s Avatar
    Sep 2009
    manchester
    74
    Replacing rear bulbs on my old punto used to be a right nightmare you needed about twelve pairs of hands, a special little plastic socket thing and an insane amount of patience. But the best design feature was a whole just bellow where the bolt is, so if you didnt have hold of it when unscrewing if would fall into a void space in the bodywork with no way of retreiving it!.
    Solutions the cause of all known problems!
  1. Replacement Simple Front End for WinUAE?
    By Yanni Oblivion in forum Amiga Emulators
    Last Post: 9th May 2009, 19:58
  2. Brighter Head Lights
    Last Post: 5th December 2008, 14:39
  3. A8n-e noisy northbridge fan replacement.
    By J T in forum PC - Windows, Linux, Mac
    Last Post: 6th August 2008, 21:34
  4. Anime Picked up a bargain
    By FOL in forum General Chat
    Last Post: 6th June 2008, 10:23
  5. Oldskool Uk plan Amibench replacement
    By Merlin in forum Amiga
    Last Post: 5th December 2007, 21:47
