Results 1 to 4 of 4
Thread: Floppy Problem?
    VirtualRyan's Avatar
    Mar 2009
    Question Floppy Problem?
    Hi had amiga as a kid and just bought a 500+ but it only reads floppy disk when first turned on it loads and works fine but if there is no floppy inserted when turning it on it wont recognize when one is inserted at animated insert disk screen.
    is this normal or a problem ??
    Hi Ryan and welcome
    I've never had that problem with any of my Amigas but it could be down to a few things. The most common is that the drive needs cleaning. Two methods are to use a floppy disk cleaner or to open up the drive and clean it with some electrical cleaner and cotton buds.
    Alternatively it could be a faulty chip on the motherboard. But I would try cleaning the drive first.
    Lugosi's Avatar
    Apr 2009
    Germany
    Is it possible that the floppydrive in your 500+ isn't the original drive, but an unmodified PC-device?
    I'm asking, because what you describe reminds me of how my miggy acted when I had replaced it's original drive with one from an old junk-PC.
    WolfMan's Avatar
    Mar 2009
    11
    Same problem on my A600...But a floppy disk cleaner, resolve it...Works very fine now...
  1. PCMCIA Problem
    By Castelle in forum Hardware
    Last Post: 17th May 2008, 20:33
  2. Problem with CBR and CBZ files
    By Ghost in forum PC - Windows, Linux, Mac
    Last Post: 3rd May 2008, 22:36
  3. Power XL Floppy
    By StuKeith in forum Hardware
    Last Post: 7th March 2008, 21:36
  4. USB HD floppy drives
    By Stephen Coates in forum Hardware
    Last Post: 5th November 2007, 20:12
