Results 1 to 10 of 30
Thread: HDD problems
Hybrid View
    HDD problems
    I've just installed the 40GB 2.5" IDE drive in my A1200. I have it connected via a buffered IDE interface.
    The drive boots into Workbench 3.1 (classicWB) perfectly well. However it is only showing the boot partition. The other 4 partitions on the HD are not being shown.
    I thought this was because IDEFix hadn't been installed, so I installed it and then restarted the system, but still only the first partition is appearing and I cannot see or access the others.
    What else do I need to do to get them to appear?
    When I installed IDEFix'97 I just quickly ran through the default installation, but then skipped the CD part (as I've not added the CD drive yet).
    Does anyone know?
    How can I test to see if IDEFix is running?
    Dangerous Inactive Member
    woody.cool's Avatar
    Jul 2008
    Northampton UK
    409
    AmigaOS doesn't see anything higher than 4GB usually (iirc), might be better to choose a different file system than OFS or FFS etc.
    iirc, you can check if IDEfix is running or not by trying to run C:IDEfix from an AmigaDOS shell window, you'll be told if it's already running.
    For those who dare! ClassicWB dev
    VIP
    Forum Mod
    Chopper Challenge Champion, The Collector Champion, BombJack Arcade Champion, Turkey Shoot Champion, Paintballing - Assault Champion, Tower 13 - Adventures In Body Saving Champion, Himalayaya Champion, Sea Dogs Champion, Yeti Sports 1- Long Shot Version Champion, Operation Switchover Champion Bloodwych's Avatar
    Dec 2004
    590
    Also how big is your boot partition?
    Live Long and Procrastinate
    A500 Batman Pack
    Classic Workbench
    woody.cool's Avatar
    Jul 2008
    Northampton UK
    409
    Best size boot partition is less than 2GB (in my opinion) but usually have my boot partition around 200MB-500MB (ish)
    VIP
    Forum Mod
    Dec 2004
    590
    Quote Originally Posted by woody.cool View Post
    I agree. I wrote as much as I know on the subject here after getting bombarded with the same questions:
    http://eab.abime.net/showthread.php?t=32256
    However, I'm only of limited help as I use less than 4GB on my real A1200.
    A500 Batman Pack
    Classic Workbench
    I installed idefix yesterday, but my hd is 3.5, i did it to setup the cd-rom. Works fine.
    I remember that he asked me if i would like to turn on the setting for hds higher then 4gb, but he only advice to do it if they were really bigger then 4gb.
    If your version of idefix didnt ask you for this i can send you my version (if it is differente)
  1. Canon EOS problems
    By Stephen Coates in forum General Chat
    Last Post: 23rd June 2008, 12:11
  2. Web Design SQL problems
    Last Post: 24th September 2007, 15:57
  3. DVD ROM problems
    By Demon Cleaner in forum PC - Windows, Linux, Mac
    Last Post: 10th September 2007, 15:02
  4. MySpace problems
    By Submeg in forum General Chat
    Last Post: 12th February 2007, 23:30
