Results 1 to 3 of 3
Thread: Power Scanner
    Power Scanner
    Today I was going through all of my boxed Amiga items and discovered loads of items I didn't even realise I had! Probably sent to me as part of larger Amiga collections.
    One of these items is a Power Scanner, from Power Computing. It is one of those handheld scanners you use to scan in pages by manually running it over a page whilst holding the scanning button down.
    Everything seems to be there. The original box is in very good condition and it looks like everything is included. The scanner is made by Trust and looks like it is a grey scan unit. The label underneath says Trust Ami-Scan Grey. Were these just PC hand scanners that Power Computing added Amiga interfaces and software too? And is the Ami part of the scanners name just a coincidence?
    Also in the box is all of the cables and a PSU, along with a scanning interface/control unit that you connect to the parallel port. Plus a software disk.
    And although I don't really have any use for this scanner as I've got a pretty decent Epson scanner I am intrigued to give it a try.
    Does anyone know what the actual interface is that the main scanning unit uses? I'm wondering if I could get it to work on a PC? I will however give it a try on an Amiga to see if it works.
    I am Legion for we are many. Staff Member
    Buleste's Avatar
    Oct 2007
    Staffordshire Moorlands
    3,977
    If i remember rightly they used the serial interface and as the PC serial is smaller then i doubt it.
    A1200 Power Tower
    OS 3.9 / CGX4 / OS4.0
    Blizzard 210Mhz (overclocked to 266Mhz) 603e PPC with 25Mhz 040 (Overclocked to 33Mhz) 256Mb RAM
    ZIV
    CV64/3D
    3.2Gb HDD + 20GB HDD
    This one connects to a control/interface box that plugs into the Amiga's parallel port. The actual scanner cable connected to this interface box via a round din connector, which is about the same size as a PS/2 keyboard connection but with a different pin arrangement.
    However it could still be a serial device, just using the Amiga's parallel port for the actual interface unit. But I don't know. Which is why I ask.
  1. TV Sky+ and Power Cut
    Last Post: 5th June 2008, 11:24
  2. Humour NES power!!
    By Demon Cleaner in forum General Chat
    Last Post: 16th May 2008, 13:58
  3. Power XL Floppy
    By StuKeith in forum Hardware
    Last Post: 7th March 2008, 21:36
  4. Power Point Presentations!
    By StuKeith in forum PC - Windows, Linux, Mac
    Last Post: 20th December 2007, 20:51
