Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Deadly Inactive Member
    Zetr0's Avatar
    Jan 2008
    523
    The only REAL way to get rid of the yellowing is to use an Acetone Bath.
    Place chassis in dish washer (gets rid of grime, grease and opens the plastic up)
    make a shallow bath (enough to cover the item) of Acetone then gently dip the component a couple of times in it.... then rinse in a shallow bath of water again gently dipping it..... repeat as nessasary
    DO THIS SLOWLY
    will say.... acetone disolves plasitc... so if you do use this method, for the love of god DONT rub the plastic in anyway... just submerg and retract a couple of times, then rinse in a bath of water, all this in gentle movement. (no side to side motion just in then out...
    eventually the yellow will be removed.... once thats done allow a final wash of water then place in dish washer on a cool 30/40c wash. (NOT INTENSIVE)
    once complete... use a matt acrylic laqure / varnish, spray gently, each coat in long arcs repeat only when its dry.. around 3 coats is more than enough... (make sure you leave enough time for each coat to FULLY dry) sometimes its best to just leave it a day if one has to!
    If i had a hammer, I would hammer in the morning, i would hammer in the evening, i would hammer all day
  2. #22
    Poor Inactive Member
    Castelle's Avatar
    May 2008
    68
    Quote Originally Posted by Buleste View Post
    NEVER Ever Ever Ever stick PCB's in a dishwasher unless you want to kill them.
    Sorry guys
    I did have to chuckle to myself here
    Not so silly as it sounds. I did 'wash' a PS2 keyboard that was dirty from my old Linux days... Dried it out on the hot towel rail - works fine now and I once accidently dropped my mobile in a glass of water!! dried that out, worked fine...
    I think the thing here is to use a little common sense!!
    Now where did I put that motherboard ??
    Btw, no joke but I have an A1200 motherboard with 3.0 roms that I will be putting in the recycle bin on Amibay now that Harrison has given me access to it
    Amiga A1200 Desktop
    3.1 OS, 3.1 Roms
    4GB HD 2.5", 750MB EXT HD
    CD ROM, 1GB CF (PCMCIA)
    Blizzard 1230 MK4 + FPU & 128 MB RAM
  3. #23
    Zetr0's Avatar
    Jan 2008
    523
    That will make some fellow AmiBayers very happy, its very generious of you!
  1. Towered A1200 030
    By Buleste in forum Ebay Picks
    Last Post: 3rd December 2007, 09:25
  2. A1200 IDE
    By JLPedro in forum Hardware
    Last Post: 23rd November 2007, 19:57
  3. A1200 Ocs, Ecs, Aga
    By Tiago in forum Software
    Last Post: 31st August 2007, 16:26
  4. Cleaning inside the computer
    Last Post: 23rd January 2007, 13:00
  5. A1200 projects
    By Harrison in forum Hardware
    Last Post: 12th January 2007, 11:15
