Results 1 to 10 of 44
Thread: Got a A600!!
Hybrid View
    Average Inactive Member
    JLPedro's Avatar
    Nov 2007
    Portugal
    150
    Got a A600!!
    Today i hade a wonderfull surprise en a friend off mine give me a A600 for free! The unit was very yellowed on the top and keys, but the real suprise as wen i taked it home and opened it! It has a 1MB expansion so 2MB chip Ram and some sort off hack and a external switch to change between kick 1.3 and kick 2.05 (37.299), both kickstarts are soldered on top one of other ( ? ) but works like a charm.
    The only problem i found appart the yelloyng was that the 1mb expantion has a battery that leaked a little, i remode-it and cleaned the area whith wd-40 (if someone knows what to do else to prevent further damage please help), the expantionn works fine, workbench shows 1,8xx mb.
    I will post pictures tomorrow of the A600 parts.
    PS: on the box also came a Spectrum +2A (havent tested it yet) and an spectrum 48k (looks very old and misses some keys and no psu so doubt it works as also i doubt the +2a works also , but i will clean it first to boot-it)
    I have another question: does the kick 2.05 (37.299) supports a compact flash adapter with a 256mb cf card?
    Wiseguy Staff Moderator
    Teho's Avatar
    Norway
    1,273
    I'm not certain of the exact kickstart version I have in my 600, but I do have a CF adapter with a 1GB card in it and that works just fine. You shouldn't have a problem I think.
    JLPedro's Avatar
    Nov 2007
    Portugal
    150
    The most important thing is that it works and try to keep the expantion working also (tomorow ill make a better inspection to the pcb and try to see iff it as damage. But it would be cool tho have the cf card as a hd cause with 2mb chip it will run all the whdload ecs games i think, or not?
    JLPedro's Avatar
    Nov 2007
    Portugal
    150
    This is the ram expantion (Zydec AmRam6001) with the battery removed and cleaned, some tracks seem to be afected. any sugestions?
    Attached Images Attached Images
    Congratulations on the free A600. Buying one always feels great, but being given one for free is even better.
    As for the ram expansion. As you have removed the battery and cleaned it up no further damage should occur. And if the ram expansion is working OK in its current state then I don't think you need to worry about doing anything further.
    JLPedro's Avatar
    Nov 2007
    Portugal
    150
    Here ara some more pics off the machine. I would like some opinions about wath color should paint the case to match the yellow keys as i dont want to buy a new keyboard. I was thinking Black (Black and yellow keys ?!? )
    Also I can't make the install disk off wb 2.05 detect the CF Card as HD, do i need some special application? or its better to use winuae to do the install stuff and just stick it to the A600?
  1. Quiz A600 Ultimate Quiz!
    By Harrison in forum Competition Archive
    Last Post: 5th February 2008, 19:08
  2. Converting A600 into a console. Great work
    Last Post: 29th January 2008, 12:35
  3. Floppy drive to A600 Help - brands
    Last Post: 17th September 2007, 11:22
  4. A600 hard disk problem.
    By wilsonsamm in forum Hardware
    Last Post: 21st May 2007, 08:47
