Results 1 to 10 of 10
    16,058
    Fit more PSP ISOs on your memory stick using CSO
    As some of you are just starting with the PSP and custom firmware, I thought I would give a little tip regarding game ISOs.
    There is a format called CSO which is a compressed version of an ISO image. Turning a PSP game ISO into a CSO can reduce the files by quite a bit and therefore give you more room to fit more games on your memory stick at once. All custom firmwares support this format so it is worth using to give you more space on your MS.
    As an example here are three games I converted recently and this is the results:
    Final Fantasy 1. ISO = 193,472 KB, CSO = 150,727 KB.
    Final Fantasy 2. ISO = 280.608 KB, CSO = 232,454 KB.
    Dungeon Siege. ISO = 881,120 KB, CSO = 729,345 KB.
    So even quite small ISOs get reduced by quite a bit. Over 40MB. And the larger DS ISO by over 150MB which is a big reduction.
    There are quite a few different CSO compression utilities available, but I used one called PSP ISO Compressor. This is simple to use in Windows and just requires you to select: CSO as the compressor, the source game ISO, the destination for the CSO to be created, and the compression ratio. Very easy and most games I convert to CSO files work perfectly.
    I've included PSP ISO compressor as an attachment. You can also find other CSO compressors and many other utilities at PSP Hacks.
    notes:
    You many notice some games will load slightly slower than usual once converted into a CSO. This is normal as the file is compressed, so the PSP has to uncompress it as it loads.
    Some games may not load once converted to a CSO. If this happens try making the CSO again, but with less compression. The problem is often due to some games needing to read data at a set rate and the CSO is too compressed to allow this.
    Attached Files Attached Files
    7,441
    I don't have a PSP yet, but this seems to be a quite useful tool. Thanks for the post , when I see Oz next week, we might try it on his PSP.
    ELITE VIP
    AlexJ's Avatar
    Sep 2003
    1,184
    I've just ran this on some of my games and the results are amazing!
    Crazy Taxi: Fare Wars. ISO = 885,088KB CSO = 339,814KB (545MB Saved!)
    Transformers The Game. ISO = 797,504KB CSO = 518,291KB
    LocoRoco. ISO = 575,936 CSO = 517,231KB
    Fantastic tip Harrison. Thanks!
    ELITE v85rawdeal's Avatar
    May 2006
    Portsmouth, UK
    1,317
    Been using this for a little while and it is a great tool, but I was wondering about the custom firmware, and what games are compatible with each version of firmware and whether they work as an ISO or a CSO.
    Seems like a project worth doing, as such a good pool of information could benefit the homebrew scene as well, with people sharing settings for the various emulators and prefered settings for games on those emulators.
    Currently, I have the following compressions done and working:-
    Final Fantasy Tactics - ISO = 399mb / CSO = 203mb
    Dungeons & Dragons Tactics - ISO = 420mb / CSO = 268mb
    Yu-Gi-Oh Tag Force - ISO = 796mb / CSO = 587mb
    This is not a signature
    16,058
    There is already a detailed list of games showing which games work as ISO's and as CSO's with each custom firmware version. You should be able to find a link to it on the maxconsole forums. If not let me know and I will dig up a direct link for you.
    May 2006
    Portsmouth, UK
    1,317
    Thanks, will head there now...
    7,441
    Not all games work properly as CSO file. Killzone for example works fine in game, but the cutscenes are jerking a lot. I compared it to Oz' one, and it was working fine for him with the same fw, but he had the ISO.
    16,058
    That happens because the CSO is compressed so for cutscenes it can't always retrieve the data quickly enough to keep up.
    7,441
    I know, I know
    16,058
    You can adjust the compression used when you make the CSO which can help.
  1. Memory issues in Apollo
    By StuKeith in forum Hardware
    Last Post: 14th October 2007, 10:37
  2. Plug and Play PS2 Modchip on a memory card!
    By Harrison in forum 128bit (6th Gen Era)
    Last Post: 29th August 2007, 13:39
  3. Your first memory?
    By Harrison in forum Amiga
    Last Post: 5th May 2007, 09:47
  4. Cheapest prices for Sony Memory Stick?
    Last Post: 16th February 2007, 16:22
