What are the extras?
60GB of extras just for the actual frontend? :blink:
Here's what there is of extras:
Acidbrain Vision Backgrounds 1024 x 768 - Nice backgrounds to add to your GameEx configuration.
Config files - Configuration files for all the major emulators for use in GameEx. Simply import into GameExConfig and enjoy! (of course you got to do a little work and create directories for roms, emulators, etc. and put the files in the proper folders.)
Default - Awesome Theme - Use this as your theme and you can have my exact setup! Simply place this folder in the GameEx Themes folder and let the retro gaming begin! **Note** My backgrounds are 640X480 for this theme. Simply replace mine with the Acidbrain Vision Backgrounds included for 1024x768 resolution.
Selector Bar ColorPack - Replace the selector bars in GameEx. Simply overite files in the Default - Awesome Theme folder (or other theme folder) with any of these cool color animated bars.
Thanks for the help guys, what I did instead was install WinUAE as normal, and then created an shorcut to the required configuration which one could double click to set up the game needed, pretty much idiot-proof!
However, that last one sounds very interesting, I shall look into it...
