Originally Posted by
Teho
This is actually the first time I've built a water cooled pc. It was easier and more straightforward than I feared, but then I spent some time learning about it before I started.
So it's an i7 Skylake 6700K on an Asus Z170 Deluxe motherboard. 16GB of DDR4 3000MHz RAM and a strix 970 GPU. Also I got one of the new M.2 SSDs which is just crazy fast. 1400/600 MBps read/write speed. Yeah, 1.4 gigabytes per second. With a clean install and nothing in the startup folder the bootup speed is... *what* bootup speed? :p
I haven't looked much at overclocking yet, just incremented the CPU from 4 to 4.2GHz as a quick test. Didn't even dent the temperature in a stress test which was as expected. I should get 4.5 easy with my cooling, and can probably get close to 5 with some tweaking but I don't intend to push any limits. I go for high specs so the system lasts a while, I used my old one for over seven years and only upgraded the RAM and GPU a couple of times.
As for the 970 GPU, I still don't have a dedicated computer corner in my apartment so I still use my pc only on a TV. Once I've torn down some walls here and rebuilt this place I'll have a proper pc monitor, but for now all I require is 1080p@60Hz. I intend to get a VR headset eventually, and at that point I'll get another 970 and run the two in SLI. I dimensioned the water cooling for three heatsources with that in mind, right now it's only cooling the CPU and the one GPU.
