I thought I would make a separate topic to put some photographs of my Dell U2410 connected to my Amigas.
Summary: It supports the Amiga's 15kHz output from the RGB port!
*Watches Amiga users dash out to buy one*
Firstly, I connected it to the Amiga 500+'s Mono port, since I couldn't find my A520.
Here are some pictures:
Attachment 826
Attachment 827
It supports Picture in Picture and Picture Beside Picture:
Attachment 828
I hooked up the A500+ to the amp and speakers as well. This could make a nice gaming setup:
Attachment 829
Here's a close up:
Attachment 830
Next I tried the A1200 with its colour composite output and RGB. It was quite a surprise that the regular PAL mode worked on the VGA input. I expected only the 30kHz modes to work.
Colour composite isn't as good quality as monochrome, but it works. RGB is much better. I had to turn the sharpness all the way down though for it to look decent, as it looked crap at first.
Here are some comparisons between composite and RGB:
Holiday Lemmings 1994, Composite:
Attachment 831
Holiday Lemmings 1994, RGB:
Attachment 832
Superfrog, Composite:
Attachment 833
Superfrog, RGB:
Attachment 834
Here is the A500+ connected to the RGB port via a Silver Box adaptor. The monitor's OSD just says the mode is 576i.
Attachment 835
I think once I have built my new desk (I'm making progress, honest), I will keep an Amiga out permanently to use on this monitor alongside the PC, since it obviously works with no extra effort.
The RGB mode is definitely better than composite. Personally, I don't think either are as good as using a proper Multiscan monitor (e.g. CM8833), but considering that we are more or less doubling the size of the image, I can't really complain. I'd say it is perfectly usable. The 30kHz output from the A1200 was good also, but it took a while to auto adjust. Some noise was noticable in all modes, but it wasn't too distracting.
When I had it connected to the A500+'s mono port, I did set it to a Super Highres Interlaced mode, and that worked fine. No flicker and was quite clear. It was certainly blurry, but still quite usable.
