I've just got a C64C and rather than getting loads of tapes and then waiting for the damn things to load I want to use a more modern method. Which of the following can anyone recommend?
IDE64
MMC64/Replay
1541U
IDE64
MMC64/Replay
1541U
Demon Cleaner is the man to ask about this as I think he recently purchased a memory card unit for the C64.
Also have a look at http://www.c64-wiki.com/index.php/SD2IEC.
I bought the 1541-III some time ago, and it's great. Have a look at Jan Derogee's homepage: http://jderogee.tripod.com/
The 1541 Ultimate is a bit expensive, and I wanted to get one some time ago, but eventually didn't, and finally ended up with a 1541-III.
Here's also an older thread at CA about it.
Are 1541-III's still about and can you use games that require multiple disks (i.e Knights Of Legend uses 4 double sided disks so there are 8 disk images + a character disk)?
Also Whilst I'm trying to decide and saving could anyone do me a tape with some games on (especially Elite)? PM me if you can please.
I've been with a Spanish friend and he has a MMC64 (now MMC replay) and works really well. Easy to set up and use. And he also had a MP3@64 and he played Mp3 from the c64 and was quite amazing has the sound of that thing is really good! :)
I'm not stupid. I know that the d64 files are stored on the SD card. When I'm on about multiple disks I mean games with multiple disk images as I know that some SD devices have had compatibility problems with multiload games and others have a limit on the number of disk images that can be mounted.
However as 1541-III is no longer in production there's no point in me looking for one for a reasonable price.
Also as there is no MMC64/Replay or SD2IEC in stock or available no point in me looking at them either. Looks like I'm saving up for a 1541U and hope they become available for reorder.
There are some good things about loading C64 games from tape:
- Making a cup of tea
- Listening to the loading music
- Making music (Thalamus' Mix-E-Loads)
- Some tape loaders let you play space invaders
- Having time to daydream
On the other hand, I've got Pirates! on tape. My god, you could prepare and eat a three-course meal waiting for that to load. Excruciating.
The fun part was when it was delivered there was already a tape in the datasette so I plugged everything in, crossed my fingers that nothing blew up, pressed SHIFT RUN/STOP (god how I missed that), pressed play, went out walked the cat and when I came back several minutes later........ the game had failed to load as the tape heads were dirty. How I missed that feeling of anticipation only to be let down in the end.
I cleaned the tape machine and loaded the tape and I was disappointed to learn it was Out Run. A truly awful conversion.
Ha! Outrun was truly dire. The Spectrum version was better.
Anyway, you didn't really expect a 20 year-old tape deck to have clean heads, did you?
In a moment of shopping madness I bought a MMC replay. I got it yesterday and have been trying it. So far I have to say I'm saving up for a 1541U.
You can't play games that are on multiple disks and multiload games don't always work. On top of that as far as I can tell the Action Replay software side of things is completely separate from the MMC side so that if you load a game via MMC you cannot then use the Replay software to poke it and if you use the Replay you cannot load anything from the MMC. All in all a very limited use product that is highly flawed.
Scratch that I'm not going to get a 1541U as they have a similar problem. I'm going to get myself a 1541 or 1541-II, shit loads of real floppies and transfer any multiload .D64's to floppy. It's cheaper and will probably work.
For anyone who's interested here's a logo I created for the cartridge case of the MMC Replay.
http://i36.tinypic.com/rw6sjp.jpg
just print it off, cut it out and stick it on to make your MMC Replay look a little smarter.
