Does anyone know this handheld console? I looked at some reviews now, and it seems to be Ok, can basically do the same stuff than the GP2x Wiz, but is only half the price, comparison video here.
http://www.dingoo-digital.com/
I just ordered one for 48£, have to test it ;)
ITEM DESCRIPTINON:
Dingoo A320 2.8" LCD GBA/ NGO/ SNES/ NES/ SFC/ CPS1/ 2/ + Emulator Game Console (4GB Built-in + Mini-SD)
Highlights:
- 3D/ CPS2/ CPS1/ GBA/ MVS/ NEOGEO/ NES/ SFC/ SMD built-in emulators
- Rechargeable battery
- Gameboy Micro form factor
- Lightweight
- Bright and high contrast LCD screen
- Plays MP4 files including AVI, RM, RMVB and more
- Plays MP3 files including MP3, FLAC, and more
- Built-in 4GB flash memory storage, built-in mini-SD slot supports up to 8GB SDHC mini-sd card memory expansion
- Cool Text-to-speech ebook reader
- Upgradeable system and emulator firmware
- Languages: English, Chinese Simplified and Chinese Traditional
Product Descriptions:
- Outlook: Premium design fashionable, slim and portable size with comfortable hand grip.
- Display: 16,000,000 color 2.8-inch LTPS-TFT true color high-definition screen , broadcast effect 320 - 240, the true and clear
picture quality, unique DVD Optimization technology
- Games: play games in (8 bit/16bit/32bit) 3D/CPS2/CPS1/GBA/MVS/NEOGEO/NES/SFC/SMD formats
- AV-out: AV-out technology gives DVD output quality, can be a portable DVD player and game console.
- Video player: Video function supports in various format such as RMVB, RM, AVI, WMV, FLV, MPEG, DAT, MP4, ASF and help users encold
video files in an easy and convenient way.
- MP3 player: Audio function supports MP3,WMA APE, FLAC audio format, synchronous lyrics display function, multiple EQ options,3D
virtual sound field, surround sound effect and play mode options. Music can keep playing while using other application.
- FM radio: Wide channel range from 76.0MHz~108.0MHz, support manual/auto channel scanning, FM recording and can keep playing while
using other application. User can save up to 40 channels.
- Digital recorder: Voice recording and supports MP3/WAV formats.
- Image Browser: Image browsing format includes JPG, BMP GIF, PNG, with zoom, rotate and image slide show function.
- E-book: Feather function includes bookmark, auto browsing, font sizing, TTS oral reading and can open with music player application.
- U-disk virus protection: Build in anti-virus software protect and keep the system at its best performance.
- USB 2.0 Transmission Interface: Support WIN2000/XP/VISTA/MAC Operation System.
- Capacity: 4GB memory, supports inserted MINI SD card to expand capacity.
- Battery: rechargeable lithium battery built-in, rechargeable by USB port or by the included USB AC charger.
Package Include:
- Dingoo A320 x 1
- English and Chinese Manual each x 1
- USB AC Charger x 1
- Stereo earphones x 1
- AV Out Cable x 1
I allready have one actually, got it a couple of months ago. I haven't actually used it very much yet. I've tried NES, GBA and CPS1/2 which all worked fine. Couldn't get Megadrive or NEO-GEO working, it wouldn't recognise the roms I had. Haven't looked into that further. SNES worked, but suffered from a little low framerate. That's all I've tested so far, I really need to study it some more.
The unit itself is pretty sweet. Has a fairly large and decent screen, and the button type and layout work fine and seem responsive enough. The menu system and method for installing and launching games wasn't the most user friendly, but you don't need to be very tech savvy to get your head around it either. The manual suffers a little from some awkward translation work, but is fairly easy to understand. All in all I like this unit, and it will definitely see some use from me every now and then.
For the price you are definitely getting quite a nice little potable system for emulation. However as I own a PSP I've not really been interested in them. The PSP emulators can run SNES, Genesis/Megadrive, NES, PS1, Neo-Geo, Some MAME, and many other emulators perfectly so it fills my needs for a portable system for emulation.
Both the Wiz and A320 are tempting and interesting systems though, and I may end up getting both at some point in the future just for the fact they are portable emulation platforms.
The only thing that might eventually be useful for emulation over the PSP is that both of these units are faster than the PSP's 333MHz one, so they might be able to handle emulation of some newer platforms like the N64 or Dreamcast given time. N64 emulation on the PSP is very slow at present.
Got mine today, looks very nice. There's about 4GB of games already pre-installed in the internal memory. But I still have to give it the thoroughly test ;)
Ok, so far so good, time for a little half way through review.
I like this console a lot, I even convinced 3 of my collegues here at work, and they also ordered one, and I ordered another one, this time a black one.
I also ordered now a 16GB micro SD card (previously using an 8GB), because the amount of games I put onto it, is huge. I would say 8GB is far enough, as the internal memory is already 4GB, making it 12GB together, but if you're like me, you want every single ROM installed to it ;)
The Dingoo uses mini SD cards, but as it's difficult to buy bigger ones, you should buy a normal micro SD with a mini SD adapter, fits perfectly. And with the buy of the micro SD cards nowadays often come the fifferent adapters anyway.
The first thing I did was installing a dual boot application to be able to put Dingux, Linux port for Dingoo, on it, to be able to install all kinds of emulators. This works fine without any problems, and after you get whole packages to install to it with already installed games, applications, ports, emulators... These packages are updated regularly, so you don't even have to install individual stuff over and over again. Btw, to install Dingux, you need an SD card, doesn't install to the internal memory.
Everything is updated via USB over the PC, and when you connect it, the PC shows you 2 partitions, the internal memory, and the external, meaning SD card, memory. I named the first one Dingoo and the second one Dingux, so you can easily hold apart, which partition has which filesystem.
The hardware of the Dingoo is really good, doesn't feel cheap, and the controls are also very well placed, ok, it has a bit of a stolen design look, but who cares as long it's good?
Ok, now about emulators from the Dingoo side, meaning Dingoo native emulators.
On the Dingoo come several emulators pre-installed, which are:
- CPS1 (Capcom Play System 1)
- CPS2 (Capcom Play System)
- NeoGeo
- GBA
- NES
- SNES
- SEGA Megadrive (Genesis)
These emulators work very good. Unfortunately they won't get any updates from the Dingoo team, but you can use the normal emulators, which can be installed to your Dingux system.
The CPS2 games have to be in .cp2 format and the NeoGeo games have to be in .mvs format though. This is not a big problem, as there are converters for both, which convert the .zip file into the needed format. Only downside is that the converted file is bigger than the zipped, obviously. Only remedy to this is to use the Final Burn Alpha emulator in Dingux, which supports zipped files, but doesn't yet play all of them, only the smaller ones.
The games are running at full speed, you can see that if you go to YouTube and search for Dingoo videos, they show how f.ex. Street Fighter II runs at full speed on this little machine. You have all the menus known from MAME or such, like button configuration, or even dipswitches.
The NES emulation is pretty good too, full speed and easy to use. Notice that all the native emulators work similar, the use the same buttons and options for every emulator, which helps when switching emulators a lot. So far I shrinked my whole NES set to 1826 games, everything included, no double files. The emulator doesn't support zipped files.
(As the ROM sets are always huge, and contain most of the games multiple times, different versions, trained, alternates, betas, previews, hacks...), I had to shrink it to the minimum of size, but still containing every single game. I did that with every set so far, you know, spare space is precious).
Sega Megadrive emulation is good too, perhaps not running at 100%, and had screen tearing with most of the games. But lately came a fix for the tearing and it works better. And if it's too slow for someone, you still can use frameskip. So far for Sega Megadrive I have installed 855 games. And again, this emulator doesn't support zipped files.
Then I also run the SNES emulator, which works fine with some games, but is rather slow when it comes to most games. Picodrive is the emulator to use on the Dingux side, because this one will get updated more often. The games I tested worked fine so far though. For SNES I have 845 games installed, and as usual, not zipped files supported.
Last there's still the GBA emulator, which works like a charm. I didn't put my games yet, because I don't have the space on the Dingoo partition, I have to put them on the external SD card, but I don't have my 16GB card yet, and the set is almost 6GB big, containing 798 files, and as you guess, .zip isn't supported.
The Dingoo has also some games pre-installed, which are normal small gamess like you also find on the GP2X, meaning official Dingoo games. Whilst not many and not overwhelming, there's 7 Days, which is in 3D and kinda Silent Hill game setting, and also pretty good.
Also tested were, MP3 player, great, flash player, great, video player, great, photo browser, great, and as you perhaps know, you can plug it to your TV, which seems to work fine, but I didn't test this yet.
Now let's go to the Dingux side. Switching the Dingoo off, then on again when holding the select button, takes you to the Dingux, if it is installed of course.
There you have also games installed, and also ports of f.ex. Doom, Duke3D, Heretic, Hexen, Rise of the Triad, Spear of Destiny, Wolfenstein 3D, Quake... mainly old 3D shooters.
Here you can also overclock your Dingoo easily by chosing at which speed it should run. Btw, this is alo possible in every emulator.
Coming to the emulators now.
There's ScummVM, I didn't test this one yet, games are really big, and also moving a cursor over the screen with a digital pad isn't the fastest, but I surely will once test it.
Then we have MAME4All, which is the same like on the PSP, it uses an older set, which is 0.37b5. You can still find torrents of it if you do a search. I use this set, and have 2261 games for it. It works perfectly, at least most of the games, but you still can tweak before running the game. And who doesn't like MAME games? Supports zipped files.
There's Final Burn Alpha, which is very new, but already runs some of the CPS1, CPS2 and NeoGeo games. So far I only have few games installed, as most of them I will probably run through the native emulators, as they're faster and support all of the games. Have to see how often this one gets updated. Supports also zipped files.
We have SNES9x, which, as you probably notice, is for SNES. Tested it, working fine, not better imo than the native one, but at least it will get updated from time to time.
Nofrendo is a NES emulator, which is an alternative to the native NES emulator, but which one works fine enough to run most of the games.
Gnuboy is a GBA emulator, but again the native one runs the games just fine, so you have to see for yourself which one you prefer to use. EDIT: Actually it runs only Game Boy and Game Boy Color games, not Game Boy Advance, zipped files are not supported.
SMSPlus is again for several SEGA stuff, I use it mainly to run my Game Gear ROMs, meaning 219 games, which run unfortunately in a small window, the screen isn't used at full resolution.
PicoDrive is a SEGA Megadrive/Genesis/SEGA CD, but I also use the native emulator. It's like with all the other native emulators, it's up to you which one to use, you just have to try which game runs better in which emulator.
GP2Xpectrum is obviously a Spectrum emulator which comes from the GP2X. It runs fine so far, but I didn't test it fully yet. Tested with .dsk, .tzx and .tap files, and they all run perfectly. Supports zipped files.
OpenMSX is an MSX emulator, and although I tested it, but didn't put games yet (only 3), I don't get them running because a cartridge is missing, which is needed to run the emulation. So it boots fine, which takes a lot of time not seen with other emulators, and then says that the cartridge is missing. I have so many, but I don't know which one to use, and where to put it yet. But I guess a faq will bring me further. EDIT: Works fine now, without adding any ROM files, games just run fine.
Hatari is an Atari ST emulator, tested with 2 games, and it works also very good, although I have to go deeper with that one yet. Supports also zipped files.
Stella is the Atari 2600 emulator, and it works just fine, I put 586 games on it, not because they are gems, but because they're very small in size, and obviously if I show someone the console, it has to have as much stuff as possible ;)
For the C64 there's 2 emulators at the moment, Frodo and Vice, which work both fine, but games I tested had some slowdowns, and some work better in Frodo, some better in Vice. But I also have to say that the Dingoo Vice port came out some days ago, and carries version 0.1, so very early stage of emulation. I'm currently shrinking my C64 set (over 40.000 games), to install, but that takes me a lot of time when I want to shrink it to a reasonable amount of games, there's just so many :o Supports also zipped files.
And finally there's a PC Engine emualtor called uPCE. I installed 103 games to it, and the ones I tested worked very good. I think this one is also very new and still will get updated.
Ok, I still have a lot to do until it is really like I want it to be. But I do everything here at work, where I have to time and patience to do it. But as a final word, I can already say now that I don't regret the 48£ I spend, and I definitely love this handheld, well build, great software and loads of fun. If you want a portable device, which only weighs about some gramms, lasts for 7-8 hours and you're into emulation and retrogaming, just get one, you won't regret.
Happy gaming :)
No Amiga emulator?
Nope. I mentioned that already the C64 emulator struggles sometimes.
The NeoGeo ROMs have to be converted into .mvs files, otherwise they don't run.Quote:
Originally Posted by Teho
MegaDrive games have to be in .smd format. If you have .bin files, just rename them, and they will run, no conversion needed.
Sounds like a great little device from your initial testing and review. Very tempting to buy one, especially at that price, but I then think of the PSP and the fact it can run SNES and Megadrive games perfectly at full speed without problems, and has emulators more all of the systems you mentioned and most work well. So I will probably not bother and stick with the PSP for mobile gaming for now.
Ok, but the battery of the Dingoo lasts for 7-8 hours, at that point the PSP already died, just imagine you being in a plane. And how big are the memory cards for the PSP, what's the maximum size? And it's 5 times lighter, you can put it in the front pocket of your jeans, it's like having a mobile phone. I totally agree with you and the PSP, but as a mobile device I think the Dingoo has more advantages, it's really mobile.
Emulators will still be updated, and there's more to come in the future. And for a third of the price of the PSP, you can't go wrong.
How about Frontier on the Dingoo:
http://www.youtube.com/watch?v=bIVhL...layer_embedded
That is a good point if you do a lot of travelling. I generally don't so it isn't such a problem. As for battery life, I've managed to get my PSP lasting up to 10 hours on a full charge as I run games and emulation all from memory cards so it isn't draining the battery accessing UMD discs.
I think with the latest custom firmwares you can now use 8GB Memory sticks. At the moment I have a couple of 4GB Memory sticks which can fit a lot of software and roms on them and are more than enough for my current needs.
I now added 4170 Spectrum and 445 MSX 1&2 ROMs. There will be hell of a lot of ROMs on that little sucker in the end ;)
:lol: And yet you probably still won't play any of them! ;)
Much like me with my emulation system and PSP. Both are heavily loaded up with emulators and roms, but I always seem to boot up and play the same games... :hmmm:
Added 4290 C64 games and 1520 Atari ST games.
Together I have now 17.919 games installed, without counting CPS1, CPS2 and NeoGeo, I still have to test and convert these to see which ones I will put onto it.
Coming close to the 20.000 games, added Game Boy 571, and Game Boy Color 465 games.
:lol: Lets see. If you just tested each game you now have installed, with an average of 5 minutes each, you would need 1667 hours, or 69.5 days! Although with your job it's doable. ;)
Yes, I figured this out before I left for that job I've been on the past weeks. I installed only a select few titles I thought I'd actually be playing and took the system with me. Not that I'd have much spare time to use it, but had a couple of hours in the evenings if me and my colleague wasn't doing anything else. Also, was great to pass the time on the plane with it. Played a couple of arcade beat'em-ups, me and my mate passing it between eachother every other credit.
The rooms we had had old 19" CRT TVs in them, with a scart connector on the back. Had to get a longer cable for it, but otherwise hooking the unit up to those TVs worked fine, so spent many an evening playing SNES RPGs before going to bed. :)
Have still to test the TV out yet.
Btw, I got my black Dingoo today, now starting to install Dingux. I will use the 8GB card I still have for this one, won't buy another 16GB, they're still too expensive, got one from eBay, really cheap, for 36€ with shipping. In the shops here in Luxembourg they're still above 50€.
must read all this post again, but,
Demon, Teho, do you know what is the average price in ebay for Dingoo 320?
i see most of them around 80 pounds, but i can see some at 60 pounds...
what specs should i look for? any significant differences between models?
or are they all the same? all fo them are ok for the ps3 stuff?
It should be 50£ now, something like that. There's no real differences, only that some are form China and some from Hongkong, can't remember anymore which ones are the original?
This one's seems fine, even shipping is free:
http://cgi.ebay.co.uk/Dingoo-A320-Em...item2a00d46282
Or you could try somewhere like http://www.renchi.com/renchi/Cool_St...tion_Black.htm
i have a dingoo now for a couple of days (is from a friend) e will try to put linux on it...
any tips about how to do it? and where can i get the software?
thanks
Check out Dingoo-Scene, I think they also have tutorials there.
