No video on power up on A600
Hello fellow Amigans :)
Recently, lurking this forum and reading on the web of those fancy IDE to CF adapters, I finally decided to get one for my A600 (KS 2.05 Rev 37.500), but before that, I wanted to check if my Amiga was all right (the last time I used it was one year ago).
The Amiga has stayed all this time in a closed closet on the outside (not directly under the rain, though), so it might have got some humidity.
I remembered that the PSU did not work, so yesterday I opened it and soldered again a desoldered wire. After that, I powered up my A600. Then something strange happened.
The Disk LED is turned on all the time (that's strange, seeing I don't have an HD in it... yet) and there's no image on video. After opening my Amiga, I found that a LED cable was desoldered. After a quick soldering, nothing changed. Oh well, that's not the big problem right now.
The big problem is the video. The Amiga seems to work normally, as I hear normal disk boot and I've even tried loading a disk in it. But no video.
Sadly, I've lost the RF to Aerial cable and the Video port to SCART cable, so I'm just using a composite cable for the moment. I've also tried spraying a bit of Contact Cleaner on the Composite outs, but still no dice. It also seems that the audio connectors don't work too, but I'm not too sure about that.
Someone got any idea or knows the problem?
Sorry for the long wall of text... And thanks to everyone willing to lend some help to an old Amigan :)
