Amiga file system for large HD
I recently obtained a very old P1 IBM laptop for free. My initial thoughts were to install Linux on it, but I cannot get it working because it's missing the PSU. It also has no CD drive or USB ports so is quite useless anyway.
So being as this is all but useless as I cannot power it up I decided to open it up and see what was inside (as you do). The system specs state a 1GB HD which I thought would be great to use with an Amiga. Imagine my delight when opening it up I discovered it had been upgraded to a 6GB 2.5" HD. :D Excellent!
So this is now going to a new home in one of my A1200's.
Now the question. I've always just used the FFS with Workbench as I've only ever had HD's under 4GB on Amigas. To format the HD to its full 6GB what is the best Filesystem I should use?
Also it only has KS3.0 roms in the A1200 at the moment so I will be stuck with WB3.0 until I get some 3.1 roms, then I will update it to WB3.9 which I understand directly supports larger HDs as standard. Is that right?
