Hey all, trying to do screen shots for games in the 'A' category, but I can't seem to get Alien Legion to work. The screen flickers, like there are two scenes on the same screen. Anyone know of the settings to use for this game?
I just tested with some different configs, but that doesn't seem to change anything, I get the same flickering during the game. I tested with the Quartex cracked one.
Yep that's the one I have also
Try booting with the joystick in port 0 rather than port 1 and see if that fixes it for you.
Hmm well it was a very quick diagnosis because after a few moments the game started working fine for me and then when i rebooted with the joystick in port 0 it remained fine.
I'll take a closer look.
edit: works fine with cycle exact ticked.
It is always annoying when a game won't work, regardless of what you try. I had that issue with a few while adding the Christmas games to the site. I did finally get most to run, but it needed some fiddling.
Great work. :thumbs: It normally is always a single little option that makes all the difference. :)
Bargh! cheers for that!
